well, I was in the garage today porting a set of 308 heads. the bit decided to kick back at me and hit the intake valve seat. very slight knick. will a new valve job fix it??? never had this happen before
The stem height with a 1.78 valve in a 1.88 seat cut is 1.942 inch.
With 1.88 valve the stem height is 1.890 inch, so that will give you about
0.051 inch to cut with 1.88 valve upgrade...
The 308 already has 1.88 valves.
ThisIt's hard to say without actually seeing it but if you say that it only nicked it you should be able to just touch up the seat. Besides a good valve job will just enhance your port work.
As said above if you do intend on putting in a larger valve then you have nothing to worry about.
Ted
