I guess I am all over the place with this, so, sorry for all my posts... here we go again...
I was contacted by a fellow member here on the board (he will remain anonomous, I hope he will be okay with me doing this)
He has a 340 he offered to me, and since I aint no mechanic, thought I would post his comment to me (I hope this is not going to offend the seller) to see what you all think. Here is the quote:
This one is a 69 engine with 68 casting. Speed pro .030 forged pistons, with the .040 head gaskets should be about 10.1 CR, bushed steel crank .002 (polished) with new bearings. so can go Auto or 4-speed, Direct Connection .508 camshaft.
X heads fresh from the machine shop (Martin at B&M engines) some mild porting, gasket matched runners, cut for PC seals and has double springs and titanium retainers.
About 500mi on the pistons and cyls no ridge and good cross hatch. From its looks I don't doubt.
I picked it up from a guy parting his project. Pulled it down to inspect and put new bearings in it, just because I was there. Crank was beautiful and amazingly unturned. I sent the heads in to get checked as I was going to use the engine. I am looking to get 2k. Tough to find and build a 360 for that.
Thought I would give you another option.
So if i can round up enough cash, what do you think? At least this seller knows the history of the engine, its complete, and presumably we could do a leak down and compression test.
I was quoted $2k to have my 318 rebuilt, which I decided to pass on. Then I decided to do a Magnum 360 swap, but then I found out that the 89-91 LA 360's have the roller cams and some other advantages, then I thought maybe I could clone my Dart into a 340 :glasses7:
Somebody just shoot me!
