pettybludart
I was out for a drive in my 68 Barracuda today,when applying the brakes the peddle feels hard and the car seems like it,s loseing vacuum(low idle,seems like it,s running on 7 cyl??)I checked for vacuum leak,alls good.The brakes are all new and the power booster looks newer(holds pressure)The PO owner had all brakes,flex lines,drums replaced,so I,m a bit confused as to why the brakes feel the way they do after checking for vacuum leaks?Maybe the shoes need adjusting?I,m new to the power drum brakes,so any help would be appreaciated.Thanks.
Could it have something to do with the proportioning valve?
