Power steering help
Jeff Lemon
Thomasville,Ga.
Trying to install PS on a 1965 Plymouth valiant with Vintage air / 6 225 engine. Have PS pump , gearbox and brackets that came with the pump and Cannot install. Need members expertise, experience. Can this be done? Need help? Thanks, Jeff
It looks like It needs a bracket on the left side of the engine where there are 3 threated holes one being where the ground cable
is screwed into.
It shouldn't be very difficult. Are you sure you have the correct brackets? I think the /6 and v8 ones differ. You will also need a crank pulley with the extra groove for the pump, also the right belt.
