moparspares
Hi
I pressed my powerforce balancer on today and my crank pulley was not lining up with the other pulleys.
Took it back off and compared with a standard balancer and the standard one has metal flange on the shaft which prevents it being pressed on to the crank to far. Pried the flange off the standard one but it wont fit on the powerforce balancer because it interferes with the weights.
Anyone else struck this problem and what did you do?.
