Powermaster 8172 alternator.
oldkimmer
Kindersley, Saskatchewan,
who here runs this alt...........can u use the factory big block mounts.....or do u know what mounts I need...do I need to install a relay at the rear, along with a fuseable link on each end, what size wire do I need to run from the battery in the trunk all the way to the alt at the front, ur help is very much appreciated............thanks............kim.....
Kim I think that is the one I have, I did the bat in the trunk did it a bit different though, I have 2 ga from the bat to a separate lug in the engine comp then basically using the stock relays etc, I did run a new 10ga to the stock wiring, I did it this way since most of my 'other: power draw is in the trunk, fuel pump, vac pump, works great for me so far.
Kim I just looked up that alt mine is a 90A squareback style but the principle is the same except hookup itself.
