Pro-Junk Yard dakota got a new best tonight.
mopar65
Laquey MO
I got to race my dakota tonight at a test in tune. Last Saturday I raced during the day and the weather was in the upper 70. I ran a best of 7.34 at 92 mph. With a 1.60 60 foot.
Well tonight I ran
1.57 60 foot
7.15 1/8 mile
95 mph
11.24 1/4 mile
114.60 mph
I ran two 7.15 1/8 times to night. I was shifting at 6500 and going through the traps at around 6600/6700 rpm.. so what kind of converter slip do I have?
That's a quick kota! I'd like to see some pictures of it and some more info please!
Hi thank you. I have a 96 dakota SB truck.
Has a stoke bore,stock crank,stock rod 2000 360 magnum. It does have KB107 pistions though. Has a comp 550 solid lift cam. New trickflow heads, PRW 1.6 roller rockers. Indy cylinder head single plane intake. Holley 800 DP. Hooker 1-5/8 headers. 904 transmission with a 8 inch coan converter. 5500 stall. Ford 8.8 rear-end. Full spool with 4.30 gears. Hoozer 28x9x15 slick.
Looks like the converter slip is in the 11-12% range.
Is that a lot or what do you not want to go above? This comverter wasn't built for my dakota. It came out of a mid 9 second small block duster.
It can't be calculated without knowing the tire roll-out and total gear ratios.
OOps I missed post 4
Super nice looking truck.
Thank you. I call it the pro-junk yard dakota, because I have parts from 5 different dakotas on it. Lol I am useing the complete set up from caltracs.
What are you using for traction aide.
That is badass!
