bentdart47
FABOlous
Thank you!
Hello All,
Just recently I received my GTS 4 bar with watts link rear suspension. I will share my build here over the next weeks. I plan to first mini tub my car to allow for wider tires then to install the GTS 4 bar and new custom fuel tank. There's also a small list of reinforcement mods I want to do while I have things blown apart.
Very very cool I have often thought about boxing that section behind the rear seat. Think it will have much affect? I have heard that non hart tops or post cars are stiffer back there so there could be some flex and movement going on.
what are the tabs on the oval pipes for ? been thinking of oval ,out the side for my fish, but don`t really want to add the weight. 3 1/2" dumps are fairly heavy to start with.I've been waiting on some parts so I decided to start some chassis stiffening work. The side pieces will weld in and the center piece will bolt in so I can get to the trunk should the lock ever fail. I used just 22 gauge but you'd be amazed what some dimple and flange work will do to a panel. These should tie up the rear really well with minimal weight. I will get them welded in a little later when I'm doing the exhaust and trunk floor. I also started my side exit exhaust, it will make sense a bit later.
Here I am after weld in, things went good. I built in a flange all around the edge of the panel and it's welded to both the old floor and the frame rail sections where the old floor was spot welded. I went ahead and started the weld nuts for the gas tank and coated the bottom side of the floor with rust inhibitor and then a coat of undercoating. I will be using six 1/2" weld nuts, three per side to secure the tank.
