If you are not trying to save the seal than removal is easy. take a box cuter blade and cut along the outside seal to remove the lip. At that point you should see the edge of the glass. From there depending on the amount of sealant used to put it in originally, you should be able to push it out. If there is a bunch of sealant holding it in, you may need to run a wire along the inside border to cut through it to get it to release. Im sure there are more than a few videos on Youtube showing the process. Dont be concerned with finding one for your exact car. Windshield install is for the most part universal within a given period of time. Any 60, or 70,s models should give you a good idea of what to do.
