Here it comes
Orient the thing with the switch facing left and the long hex nut up.
Oriented thus, the port on top is from the M/C rearmost chamber to operate the front disc brakes. The two immediately below it go out to the front brakes.
The next one down comes from the M/C frontmost port for the rear brakes. And of course the lowest port goes out to the rear brakes.
The little pin you see sticking out to the left in your picture should have a boot on it to protect it from the elements,IIRC. I have not seen that outboard device on any 1972 to 1975 Combination valve.It kinda looks like a Metering valve. I seem to remember that valve being a separate valve on KH equipped A-bodies, from 68 to 72. It was plumbed into the front brakes. The idea was to slow down the application of the front calipers, to give the rear shoes a head-start.
My KH system doesn't require it. If you wish to plumb it in, then yes you would need to jumper it in. It would be the first to receive fluid from the M/C rearmost chamber for the front brakes.The outlet would then go to the TOP of the Combination-valve.
If you are gonna run 275s or better,out back, you won't need a proportioning valve if you install 13/16 or smaller rear wheel cylinders, and have 10" drums.
The safety switch is good to have, but in my opinion kind of a novelty, cuz when it lights up, you will already know all about the pressure imbalance going on. The block is however a convenient place to route all the lines from. I just gutted the proportioning part of mine, so the rear w/cs get full line-pressure.
I have 7/8 w/cs and cannot lock the 10inchers back there with 295s, on pavement.
