nm9stheham Well-Known Member Joined Dec 20, 2013 Messages 12,087 Reaction score 4,282 Location Waynesboro, VA Oct 14, 2017 #26 If it just to make it run, then I'd carefully pry out the old ones with the engine in place and put in the rubber ones.
B Bts68cuda1 Member Joined Sep 22, 2017 Messages 17 Reaction score 3 Location williamstown Oct 14, 2017 #27 trying not to do more than needed but dont want them to start just going every so often. There are a few nm9stheham said: If it just to make it run, then I'd carefully pry out the old ones with the engine in place and put in the rubber ones. Click to expand... I cannot get the ones out from under the engine mounts or above the bell housing. If it were only 1 freeze plug and it was accessible then by all means yes but its 4 or 5 of them in the worst spots so mind as well pull it
