Unless you are very careful or very lucky, you will spill a LOT of transmission fluid unless you do one of two things. Either drain the trans or block off the tailshaft (you can use the driveshaft yoke if you remove the front u-joint).
You can pull the trans up out the same way the engine came out or you can drop it down, jack the car up some, and slide it out from underneath. The hard part is usually getting the engine out.
So what are your plans once the engine/trans are out?
LOL that is funny... I did the same on my first engine and trans pull many years ago.... expect I was under the tailshaft when I pulled the driveshaft and became 'kitty litter' myself. Nothing that a lot of soap could not cure!It looked like a blood bath on the floor, but thats what kitty litter is for.
I keep spare yokes for 727 and a 904 now.
