I have a 72 duster with all lights that pulsate at idle, and even more when the rpms go up.(they strobe) not just brighter with rpms and dimmer at idle, they actually pulsate. I ran the wire from the alternator to the battery side of the solenoid, thinking this may stop the problem but it didn't help. I unplugged the voltage regulator and the pulse stops, could this be a bad regulator/alternator (regulator/alternator is new). What could be causing this problem.
