Here's how we bent the one for my son's 360 for his Holley carb. You can copy the end at the fuel pump, and adjust for the inlet location at the top.
I just get a 60" piece of 5/16 steel tubing with double flares on both ends, then bend the part for the fuel pump and get it to the fuel filter location, then cut it.
Then I work from the carb back to the fuel filter.
No double flare tool needed.
I like to use an old wire coat hanger to make a model of my planned routing and test fit it for clearance, then try to copy the bends onto the steel tubing to match.
You want to come right out of the fuel pump with two 90° bends as close together as you can get them (a full 180° bend will work if you can make one, if not get as close as you can with two 90° bends as close together as you can bend them. You have to keep it tight to get around the alternator and fuel pump here. But for the second 90° bend, you want to put about a 15° angle forward on it, to get it close to the fuel pump center.
Then make it come straight up between the dipstick tube, alternator, and alternator
brackets.
Then figure out where you need to bend to go for your carb inlet, and cut for a fuel filter.
Then like I said, start at the carb, and work your way back to the fuel filter.
For ours, you can see the hose takes a 90° bend after coming out of the carb. I bent a piece of steel tubing to 90° and worked it into the hose to keep the 90° bend from kinking the hose with inertia and vibration which could restrict fuel flow. I use the 90° bend to keep the form rigid and support the inside of the fuel hose from collapsing from possibly kinking. Like a steel sleeve on the inside of the hose...
