garyfish340
There's a relay attached to my relay. All I can tell you is, on the Red plug there is a yellow wire going to the middle bulkhead connector 2nd wire down on the right, it also jumps from the red plug on the mystery relay to the starter relay. Than there is also a yellow/black wire it goes to the passenger side bulkhead connector, top left wire, than there is a little brown wire that I swear I didn't cut, it must have been gremlins.Those are all on the red 3 prong connector. Than there is a brown single prong connector with a bigger brown wire, and it goes to the drivers side bulkhead, first wire to the right. Could this be for the window wash fluid motor, a pace setter, a city horn, or air conditioning. This car is originally a 1975 Plymouth Duster, slant 6. w/ air conditioning. Automatic trans.
