downsr
Finally got leaking mopar performance valve covers fixed by notching the the covers around the intake runners.Still have one leak left.With the inspection cover off i can see a drip come off the oil pan seal in the rear.Is there anyway to tell if its the rear main or just the pan seal.I believe i may have caused this by not having breathers on the valve covers.Since then i have installed a breather that runs to the air cleaner and a stand alone breather on passengers side.Drivers side has pcv and twist on fill cap.It has a k1 rotating assembly.Do they take a special seal or are they all the same.Lastly if i need to change the rear seal is there any place i can find out how to do it.I only want to do it once.What is best seal?
