W2-1969Dart
Degreeing in my first camshaft not sure if the cam is ground wrong or I'm doing it wrong. Intake CL 108.25 and Exhaust CL 112 which are good , Lift 372 thats ok but when I check duration I get [email protected]ure Setting dial indicator to zero at base of cam rotating to .050 on the dial read the degree wheel 7 rotate past max lift to within .050 of base read degree wheel 43 add the two together plus 180 =230 any ideas cam is P4120655
