olddman
I am hoping that someone out there can help me out again!! Have a 1965 Dart GT with a Charger 273. Need to replace the radiator hoses, but having trouble finding the upper hose. Does anyone have a brand and part number for the upper radiator hose. The hose that is on it now has a ninety degree angle right off the thermostat housing and then you have to angle it over to the radiator inlet. Radiator inlet is offset to the drivers side, thermostat outlet is straight neck. Seems like there should be another angle to the hose so that it would fit better. Just does not look right when you have to force a bend in molded hose. Thought about a flex hose, but would like to use the correct one. Any help with this is appreciated.
