cdwmotorsports
BB Demon and I have switched the water pump housing and radiator. The top hose now goes to passenger side and the bottom to drivers side. Does anyone know what hoses I should get?
Intercooler Pipe Fabrication
Buy just what you need and bend accordingly.
Couldn't help but notice the race distributor. With the tach drive. So whats at the end of the cable? I run that distributor in my 64 plymouth. It drives a Stewart Warner tach that will be mounted in the instrument cluster. Just had the tach rebuilt$$. How is yours working out?Alternative for upper w/26" radiator…….
It's SW. Works fine but it's not seeing a lot of run time these days. It came with the car trade I did in '80. (should have kept the '71 Chally) A little hard to see the signal indicators as they are behind the bracket. Over the years I tried larger electrics and the SW sat on the shelf. But they overwhelmed the dash and I got some "yuk!" comments I had to agree with, Lol.How is yours working out?
A little shop,valley tach and speedo. It cost $185.! Yeah, steep! But the guy replaced most of the guts. I had spent some time messing with it so i recognized the parts he fished out of the trash to show me. And he replaced the cables core,a different tip and the housing end. I had been using a moroso tach. Only took 3 business days. Not positive on the name but i can get you an address and all that if your interested. I have no idea what a new tach goes for,probably not much more than what i paid....hangnOut where did you get your tach rebuilt and cost if you don't mind me asking?
Thanks, Jeff
I used Dayco# 70776 for the upper
And
Gates# 20558
Had to do a little trimming but fit well.
It really depends on which radiator you have. Different radiators have the hose outlets located in different places.
Yes I did have to trim a bit of the hose. It’s real close to the strut rod but it does clear.
I’ll probably put some type of plastic shield there just for a layer of protection just in case...…..
To answer your statement this is the radiator I am using...
26" Big Block Mopar Radiator
good idea, i've zip tied a short section of rad' hose over a hose if there's possible clearance issues several times in the past. sort of a sacrificial part that can be replaced from time to time if need be.I’ll probably put some type of plastic shield there just for a layer of protection just in case. But as it sits right now there is clearance and no sign of contact while driving. Granted I’ve only put 20 miles on it so far.
neil.
Here is a 27 inch Cordoba radiator in my Duster. I just had the radiator shop put the lower outlet where it had to be so the hose would fit correctly. The outlet on the lower tank needs to be positioned between the oil filter and the strut rod. Unless the radiator was built for this exact application the outlet will most likely be in the wrong spot.
