Rear Brake rebuild?
Discussion in 'Brakes for your Classic Mopar' started by Moab-MoparKid, Feb 17, 2017.
  1. Moab-MoparKid
    Moab-MoparKid Member
    20
    10
    Feb 12, 2017
    Moab, UT
    Local Time:
    5:21 AM
    I am in need of rebuilding the brakes on my 8 1/4 rear end and I have never done this before so I am curious on what is the best way or place to get all that I need to put them back together.
  2. RustyRatRod
    RustyRatRod Just another dumbass. FABO Gold Member Technical Editor
    43,810
    7086
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    7:21 AM
    Generally, the hold down hardware such as springs do not need replacing unless something is broken. However, the hardware kits are so cheap, it's still a good idea.
    First, I recommend you get a factory service manual for your car. Not Chiltons, Not Haynes, but factory Chrysler. I prefer them in print, but you can download them as well.
    Secondly, disassemble and reassemble ONE side at the time. This way, you have one side to use as a guide if you need to know where something goes. Drum brakes are very simple once you understand how they work. The best way to learn is to jump in and do it.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • Moab-MoparKid
      20
      10
      Feb 12, 2017
      Moab, UT
      Local Time:
      5:21 AM
      Thank you. I'll definitely do one at a time looks like things could get a little confusing lol
      The 8 1/4 is going into the car replacing the 7 1/2. One side was all good but the other seemed to be run to the ground. Brake shoes were ground down to metal and ate a lot of the drum. Really had a hard time just getting it off and in the process bent some things.....:(
    • RedFish
      RedFish Well-Known Member
      21,642
      1090
      Sep 5, 2007
      Local Time:
      7:21 AM
      The proper spring tools will make a huge difference too.
      Some members have put pics of their assembly up here and so we can point out whats wrong.
      Better safe than sorry, or better no go than no stop.
      • MrJLR
        MrJLR Built, not bought FABO Gold Member
        2,955
        1295
        May 14, 2015
        Chino, California
        View My Photos
        Local Time:
        4:21 AM
        Best advice EVER.....:thumbsup:
        Jeff
        • Like Like x 1
        • RedFish
          21,642
          1090
          Sep 5, 2007
          Local Time:
          7:21 AM
          I have to disagree. If a previous owner/shade tree mechanic had put the parts together wrong, the sample is corrupt. Factory service manual is the best advise. First/best tool too.
        • zombywoof
          zombywoof Well-Known Member
          345
          59
          Nov 2, 2014
          here im is
          Local Time:
          6:21 AM
          all above advice is the proper way to go about it. one other thing that might help you is after you get the drums off is spray it with some brake cleaner and before you start to disassemble whip out that cell phone and snap a couple of pictures of both sides
          • Agree Agree x 2
          • Like Like x 1
          • sccachallenger
            sccachallenger Well-Known Member
            107
            35
            May 18, 2015
            north carolina
            Local Time:
            7:21 AM
            This happened to me on my new to me '89 d250, some yahoo had put the same self-adjuster on both sides. One side would adjust normally one would loosen!!
            So yeah a service manual and take photos of both sides before you touch anything! And drum brake tools aren't expensive and make the job a lot easier, get some!
            • Like Like x 1
            • 71340Duster
              71340Duster FABO Gold Member FABO Gold Member
              2,185
              644
              Apr 15, 2014
              Oak Harbor WA
              Local Time:
              4:21 AM
              Inspect the whole brake system, lines back up to diverter/master cylinder.
              • Like Like x 1
              • sccachallenger
                107
                35
                May 18, 2015
                north carolina
                Local Time:
                7:21 AM
                You know,if the shoes and drums are the same size/bolt pattern you may be able to pull the axles and swap the backing plates from one axle to another.
                I've not done this with the small axle, but have swapped between 9-1/4 and 8-3/4 with no problem.
                I'm sure someone will correct me if I'm wrong!
              • Moab-MoparKid
                20
                10
                Feb 12, 2017
                Moab, UT
                Local Time:
                5:21 AM
                Sorry for the delay everyone. Thanks for all the advise it has and will continue to help me in this process as I haven't yet put the brakes back together (hopefully tomorrow night). I got everything I need to replace all the old with new parts. I have taken my pictures to look back on as I do one side at a time. Wish me luck lol
              • 71340Duster
                2,185
                644
                Apr 15, 2014
                Oak Harbor WA
                Local Time:
                4:21 AM
                Bust a knuckle!! No, don't do that.
                • Jimacuda
                  Jimacuda Well-Known Member
                  998
                  159
                  Nov 10, 2006
                  Phoenix AZ
                  Local Time:
                  5:21 AM
                  The digital camera is a great tool. Take lots of pictures anytime you disassemble anything. Pereferably before disassembly...as well as during and after.:D
                  • Like Like x 1
