Rear leaf spring Shakle question
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
i want to put rear leaf spring shakles to raise the car up but i need bolts ....so question is ....is a grade 8 bolt enough for this job or do i need a stronger bolt .......hopefully i can get the right bolts locally today ....but i was not sure if grade 8 is good to go
Grade 8 should be fine Rani.I keep a bolt bucket from previous stripped cars as I feel that the older steel bolts are made of a stronger steel.JMO
grade 8 is very strong hi carbon steel.
here's the rub,it is so hard it is brittle and may break when it fails.
grade 5 is not as strong and somewhat softer so if it fails it will likely bend instead of breaking.
most suspension parts are grade 5 for this reason and sized appropriately.
Exactly so. I've broken a grade 8 bolt I used as a spring eye bolt. Grade 8 bolts are very strong in tension/compression, but their shear strength is not as good as "softer" bolts.
I would use grade 5 hardware myself.
I assume you want to lengthen the shackles, the question is why? It's a bad way to raise the rear end. You end up ruining the leaf springs, throwing off all the front end geometries and making the car dangerous to drive. Am I missing something?
Cuda Jim is absolutely right and it also looks hoakie as hell!!! If the springs are sagging, replace the springs with a set that are not sprung or install a set of coilovers that can be adjusted to increase the ride height but don't just put longer shackles.
I think you are fine, it should drive good. As long as you are not going with shackles like this, you should have no issues :glasses7:
I have to agree with this. I am currently saving up for some better springs. Then I'll ditch the Shackles and Air shocks. The *** end of my dart is all over the place. It looks like Crap too IMO. The Coil Overs are frowned upon by a lot of people unless you reinforce the top mount.
With a Mopar you'll find that shackles will do nothing except flatten out the back of the spring without raising the car any noticeable amount. In a Brand X car with the rear axle centered 50/50 there will be some considerable raising of the back of the car. In a Mopar the rear axle is 70/30 roughly and there's not enough spring behind the axle.
A pair of new springs would be great Rani :D
I need to up grade to new ones myself one day
air shocks and a good soft radial help's Victoria and me for now.
I would take off to Ca. with no worries.
And yes it will stop and move out of it's own way , This comes first
just stay off of bad roads, buppy gravel and don't over load it (5 peaple)
and yes :glasses7: I would use a grade 8 Bolt and the 5 would be fine on a very lite A Body :burnout:
I've had coilovers on my car for the past 30 years and have never had any issues whatsoever and have not babied it at all. Just a thought and option
This is ABSOLUTE FACT. I have used the cheap coil-over conversions from the parts store (about $30), BUT I have also found that those kits work best if you weld the upper mount to the shock.
Ya know if you were to cut thoes they would not look as bad.
