DA4AD
We were out playing around with the car tonight. I had the car bounce of the rev limiter a few times.
After a couple of passes the car started smoking (oil), upon investigation the oil is leaking out the clutch inspection cover.
Why would this happen? i don't think there would be any other place for oil to leak, would there? I will be ripping into it tomorrow.
The following questions are to try and figure out why this happened.
1) This is the breather on my motor. it is open to atmosphere, although i do have a PVC. should the open to atmosphere be bigger or piped to the air cleaner so vacuum would help?
2) Can i change the rear main seal with out dropping the crank? There used to be a tool many years ago called a sneaky pete?
3) Can you adjust the rev limiter on a MSD ignition system?
