OK fellas, apparently my 408 (LA 360 base/mag heads) has managed to spring oil leaks in every direction just from sitting in a garage all winter. the engine has probably 20 quarter mile runs last year and maybe 150 street miles, then it got garaged up for the winter. my problem is when i started it up this year. it began smoking on the pass side pretty good so i shut it down to find some oil drips on the headers...almost looking like it came from a leaky filter, but it was dry. upon further inspection there was a few drops up on the block behind the pan. so i wiped it all off, and tightened the pan bolts pretty good. and it seamed to fix it.
today i go out to adjust my shift linkage, and lone behold more drops in the exact same spot, smoke and such...so hoping it was just leftover from last time. i did some full stall launches at 4000 and then parked the car. now not only were there definite drops every time i back the car up...but the TOPPP of the motor is also covered on the pass side...there was spray on my alternator...heater hoses...and valve covers. i swear that these mopar cast aluminum valve covers, with their cheap *** foreign oil caps are a leaky nightmare. so i'm hoping i find a broken/torn gasket when i pull them off...but the leak on the rear i'm most concerned about...do you guys think it can be my valve covers leaking and dripping down out of the junky oil cap...or could it be the rear main seal? or even just the pan gasket... i don't want to pull the motor again...but are the rear seals on a 360 LA block prone to leaking? anyone else had nothing but trouble with sealing cast aluminum v covers?
thanks guys
thanks guys
