No, a regular one
It is a small pipe with a a 1 inch nut cast onto it
But the nut is only about 1/16 thick
the plate...you can use a 3/8 drive ratchet with an extension....the square end goes right into the plate bolt
oh, and I totally killed the thread on it (trying to get it off with a pair of vice grips) so if someone has a part number on one of those or could tell me where to get one, that would be great
tried the vice grips and hammer, didn't do the trick
I'm not sure if I can get the plate itself cut with the headers on, but maybe I can put a screwdriver in the holes and pry it back?
That's what's on mine and all I have seen. 3/8" drive into the square center.
This is all I have ever seen on the SB oil filter plate. They are usually tight so if they did have thin flats on there I would still use the square 3/8" drive to turn it out first.
http://www.manciniracing.com/moenoilfimof.html
