Replacement battery
Peter L
Active Member
Ontario Canada
Looking at the replacement original style AGM batteries. I have a '69 barracuda, 318, factory a/c.
There are 2 listed. Green caps, or yellow caps but they don't specify what the difference is.
How do I tell which one I need for my application?
Thanks, Pete.
Look at the cold cranking amperage and amp hour rating, and make your decision from there.
You did not say what car you have, you want an orginal looking Mopar battery, A Body should be Green, I believe that Yellow would be an E Body.
My OP stated the car is a '69 Barracuda. 'CRUZE418' states it should be green. Both the green and yellow cap batteries offer the same CCA of 750, and offer no application based on the cap colour. Just wondering.... green or yellow? :realcrazy:
Originally green and yellow caps were rated differently but were same outside dimensions. The red cap was higher rating and physically larger. Now- the difference between green and yellow caps are only the color of the caps. This allows me to select which color cap came originally on my car. Most cars had green caps, but my car having a BB motor had the more "heavy duty" yellow cap battery.
Here's a chart:
Green Caps:
  • 1966-1969 with 225, 273, and 318 engines and 48 amp alternator
  • 1968-1969 with 340 engines and 48 amp alternator
  • 1970-1973 with 225, 318, and 340 engines and 46 amp alternator
  • 1973 with 400 engines and 59 amp alternator
  • 1974 with 225 and 318 engines and 48 amp alternator
Yellow Caps:
  • 1966 with 361 engines and 59 amp alternator
  • 1967-1971 with 383 engines and 59 amp alternator
  • 1970 with 318 and 340 engines and 59 amp alternator
  • 1971 with 360 engines and 59 amp alternator
  • 1972 with 400 engines and 59 amp alternator
Red Caps:
  • 1966 with 383, 440 and 426 Hemi engines and 70 amp alternator
  • 1966-1972 Police Units with 70 amp alternator
  • 1967-1971 with 440 and 426 Hemi engines and 70 amp alternator
  • 1972 with 440 engine and 70 amp alternator
  • 1973 with 440 engine and 70 amp alternator
  • 1974 with 400 or 440 engine and 70 amp alternator
My '69 Dart with AGM green cap.
'72 with a dress up kit on a regular battery, be careful on the battery you buy, overall for looks and where the positive and negative posts are.
