It's been many moons since I've had to replace the lower control arm bushings on a Mopar. What is the easiest or best way to R and R lower control arm bushings after you have them out of the car?
The easiest way is to press out the center pin, them weld on a washer tot he old bushing. The use the largest bar possible to push on the washer/bushing. If it is welded half decent it works like a charm.
Tip**** press out he bushing quickly after welding while it is hot and it works better.
Or...... buy new tubular lowers from me, CAP auto Products. LOL
www.capautoproducts.com
Weld the washer to the bushing shell ,the side with the lip on it.You lost me on the welded washer part. Are you saying weld a washer to the same side that you pressed the pin out? How do you do that?
Auh, Now i understand thanks for all your help. Now maybe you can show me a easy way to get those pesky sway bar bushings in the brackets?
I changed some on a 68 Charger and let me tell you was not fun at all. I do remember I took the entire sway bar out to do it and then bolt it back in. I'm not going to tell the words that was used that day. LOL!
Never did one, but I do have to install my aftermarket one, and I'm looking for a kit so I can weld the ears to my Lower control arms.
Curious, what is so hard about those bushings?
I've done tons of them on Mercedes but removing the sway bar was just nuts and bolts.
Are the factory chrysler one's a nightmare?
Took me two hours, one glass tea that I threw in a fit of rage,some busted knuckles to get these polyurethane bushings in. Let me tell you they are a DOUBLE MOTHER HUMPER TO GET IN!!!!!!!!
Would a little silicon spray help the installation?
