Reverse Bleeding Hydro clutch
plumkrazee70
Medford, Oregon
Just finished installing the new 340 and the new clutch/PP (switched from 3 finger to diaphragm).
Have a hydro TOB and it bled great with the 3 finger, but with the new setup I cant get it bled. I figured there is trapped air.
I was thinking about reverse bleeding. To do this I will force fluid through the bleeder up to the master. Forcing air up, instead of down.
Bad idea?
Have a hydro TOB and it bles great with the 3 finger, but with the new setup I cant get it bled. I figured there is trapped air.
I was thinking about reverse bleeding. Yo do this I will force fluid through the bleeder up to the master. Forcing air up, instead of down.
Bad idea?
The Ford Rangers were like that.
Had to bleed up from the bottom to get the trapped air to move.
It works great.
