brandon2701
brandon2701
I'm installing a new B&M pro ratchet shifter and going from column shifter (stock) to console shift (aftermarket)......I have located my back-up light switch and have re-routed it to the new shifters switch. and now the back up lights wont turn off, any help would be fantastic thanks a bunch. The car is a 68' dart 270 originally with a slant six and was a column shift but now has a 360 w/ a console shift the car is an automatic and i now have a reverse manual valvebody in case any of this info helps you understand any tweaks the car might have. Thanks a bunch.
8)
8)
