skep419
5.9 Magnum 4 speed afficionado
I bought a vintage air by level heater (took the heater out of the dart many years ago to save weight. I live in MN and now have kids) Where the heater was is were I mounted msd box, ign coil, fuse block, etc. I have sinced moved the battery back to the engine bay and cant decide how I want to route my wires. I moved the fuse block to the fresh air delete plate under the drivers side dash.
My question is I have a ford taurus fan wired to just run on the high setting. It has a temp switch that kicks on at 185 and off at 175. With a override switch. I have a 40 amp relay that I mounted on the radiator support. How big of wire and fuse should I use? I also need 12v power for the relay used to power the fuse block inside the car and to power the msd box. (have another fuse block that could be mounted in the engine bay)
How big of wire and how big of fuse needed to power relay for fuse block inside the car. line lock, electric exhaust cut outs, fan relay (key power), msd key power, gauge lights, alternator sense wire, radio.
