Budgetmoparman
I have 3 rear ends I am swapping parts out of, all 3 are Dana 60. I will call them 1,2,& 3 to try to eliminate confusion. #1 is in the vehicle and has 4:10 gears with open carrier. #2 has 4:10 gears and sure grip. #3 has 3:55 gears and open carrier. I want to use the sure grip from #2 and put the 3:55 gears from #3 in the housing from #1. Should I use the carrier bearings and races that are already in #1 with the sure grip carrier from #2 and 3:55 pinion from #3? Or should I keep the bearings and races on the 3:55 pinion and put them in housing #1. I know this sounds very confusing with all of the numbers but I don't know how else to explain it. I am using the housing from one rear end and the ring and pinion out of a different rear end and the sure grip carrier out of a different rear end.
