When I built the 408, there was minimal bore wear, except the very end of piston travel at the top. Is there a difference between the stock ring height ( top ring) on a stock piston, compared to a kb107 piston? As measured from the piston pin? If it is lower, that would really help increase the chances of using a stock bore piston, saving some $$.
