MyBlueCuda
I've got an 8 3/4 sure grip rear end with the "741" center in it. I want to put a 4.10 gear in it. But all the catalogs only go as high as 3.73 gear. Am I stuck with this size as the largest I can go? Is there a strength issue with this differential that won't support a higher gear? Is there anybody out there that makes a 4.10 for the "741"??? (can't afford to get a 742 or a 489 chunk at this time)
Thanks for your advice.
