I saw a 5/16 and 3/8" outlet
The fuel line size is determined by the sending unit, not the fuel tank. Sending units are available with both size outlets.I saw a 5/16 and 3/8" outlet for fuel tanks on rockauto. I'll be doing my final 273 hipo build and the extra 1/16 is significant to me. Is this a typo or generous measurement? Anyone buy one and measure it?
I put the 3/8" sender in mine with the line to match. (just in case a 408 find's it's way under the hood someday)
5/16 will support 500 HP. That said we all know bigger is always better, right?
3/8 will generally take you farther than most will ever go.
That's my general rule of thumb. Course now, there are exceptions to every rule. That twin turbo alloy headed 416 build lookin for 1500 HP probably needs bigger than 3/8. But that's the radicalness that it takes to need it. 3/8 will purt near supply whatever most guys will ever build. But lemmie get that -10 out. lol
Lol. I actually run -10 to the pump and filters, than -8 to the regulator. Lol
Totally overkill.
But……we ran 11.12 @ 122 mph @ 3500 lbs with 3/8 line. Plugs looked beautiful. No fuel supply problems pressure wise either.
It's like a Dana 60 behind a stock stroke N/A 360. You know it's overkill, but it'll never give problems. Ever. Nothing wrong with overkill. It's just not necessary. That's why it's overkill. lol
I am running a DANA 60 also. Lol.
With today's crap ethanol laced fuels vapor lock is a real problem. The engine driven fuel pump sucks fuel through the line, which makes it want to separate into vapor. A 5/16 will have much more resistance to the fuel pump and will create more vapor lock issues.
Over and above this, if you have any kind of hp and intend to run at wide open throttle through the gears the 5/16 is marginal at best. My somewhat mild 408 had fuel delivery issues at the top of second until I switched to a 3/8 fuel system.
