stop the beast
Hey All,
I'm going to be running 6AN bradied stainless lines for feed and return. Anyone have a good tip on getting them through or around the front sub-frame? I didn't want to go under the sub-frame since this will be mostly a street car.
I was thinking about putting a few holes in the subframe and using some moly tubing inside of them to re-enforce the holes and allow the lines to pass through right near the factory torsion bar mounts. Problem is it might be a tight fit with two lines.
Anyone have any other suggestions?
