[FOR SALE] SB 727 W/Reverse Man Valvebody and 4000 stall converter
csx711
69 Dart GT Lemon Twist 512 68 HT Satellite 340
Richmond, CA
I have a good used SB 727 with reverse manual valve body and also a 4000 stall converter. i have a few passes on it Footbrake car. I will throw in Cooler with lines B&M Pro shifter too. Clean no Leaks asking for $1100
PM for Info
Herman
This transmission was built by Logestien Racing Brentwood CA. They are well known from the NHRA Supper Stock Class West Coast. I know the converter is not over the counter. Its custom high end it was little over a 1k valve body I'm sure he used the good stuff, the Trans too. It in my car now still. I'm just going with a racing 904 he built same converter from his sources I'm going to go with 4500, rear end changing to s60 40spline 4.88. If your local you can go for a test run. My car is a high 10s
Herman
Who made the converter and who made the valve body?
