zac_F71
I have a 68 Road Runner housing, 68/69 741 case, and 68-70 B body axles
Do I need to use shims to set the axle depth or whatever it's called? the housing has a TON of shims on each side flange..
Also I read the center section is sealed from the outer axle bearings and they require grease? Is this right?
