wardy
Ok, down here in Australia the newer gen hemi's are about as common as finding a leprechaun riding a unicorn bareback... And if you can find one you have to re finance your house!
But I've been intrigued lately and was thinking instead of buying an aftermarket LA block to build (around $3k landed) I'd almost be better off doing something a little left field and going with a hemi..
I'm building my car, a 68 valiant sedan, to compete on Australian x275 racing, it's currently being pieces together with a single turbo 360LA on e85 that should put out around the 700hp mark..
Basically I want to know the ins and outs of these engines. What years are regarded as the best? 6.1,5.7,6.4 etc?? Are some blocks stronger then others? Do certain heads flow better? I understand some of the newer ones have VCT?
Can a full programmable ecu be used to run them? Can you easily fit up common transmissions to them (powerglide,th400 etc)
I'm open for all types of advice or pointers.. Talk me into it or talk me out of it.
It won't be happening for a while but I'm just doing my research. I'd like to make in the region of 1000wheel hp, 80mm turbo (class rules) and e85.
Fire away
Wardy
Fire away
Wardy
