Having a rough time keeping my alternator V-belt on while running high rpm. Would like to switch to a serpentine style setup, but just need the crank and alternator pulleys. It’s an LA small block with the standard old style finned alternator. Will the magnum engine pulleys fit? I see those are inexpensive, and easy to obtain. If not what are my other options? I don’t need fancy polished aluminum pulleys that are $200.
