MOPARJ
What can I upgrade now?
I have recently had some issue with the suspension and brakes on the front of my 73 Duster. Sometimes, not all of the time, and usually under light to moderate braking, the left front of the car will start bouncing up and down violently. I can clearly see the left front a little higher off the ground on the left side compared to the right when this happens. When this doesn't occur, I still have a vibration, albeit, much reduced in violence under hard braking. Also, the car does pull to the right when braking. I have replaced shocks and the left side rotor is good and the right has been replaced. It was doing this before I put the shocks on. The problem is getting worse lately. Its so violent that the left front is actually bouncing until the vehicle comes to a stop. During a tire change, a service tech noticed that the right side caliper was near shot(this was several months ago). I can see this as the cause of the pull to the right under braking, but for the bouncing and shaking on the left side too? Unless, it is locking up the right side front brake completely, then Im not sure what it could be. Any help at getting this solved would be greatly appreciated.
-Justin
-Justin
