so this weekends nightmare comes from last years tranny woes that apparently are back. i blew a converter last year that clogged up my trans. causing it not to shift b/c pressure passages were blocked. i took it to the trans shop, got a new cconverter, he put in a new pump, cleaned it all out..but he did reuse my full manual valve body.. well i put it all back together today..seemed to shift correctly but would not start in park, only neutral, so i adjust the linkage till it cranked in park..and now after a few high stall launches...i'm stuck in first..it was too hot to mess with so i just garaged it...but even ratcheting up through 3rd..it stays in first....which i would assume it would at least hit pull 2nd even if the linkage was off.. unless i'm hitting every (half) gear perfectly, deep pan and 8 inch converter, so i started with about 10-11 quarts and the level appears fine....what do you guys think i'm doing next weekend?..replacing a valve body? fine tuning linkage? or pulling out the entire tranny i just took the previous weekend putting in for yet another going through
: ( great way to start racing season
