[WANTED] Short/Long 340 Engine
SharpDart71
Irwin, PA
Rating - 0%
0   0   0
Hello all. Looking for a close-to stock 340 engine to rebuild and put into my 71 Swinger. 200+- miles from the Pittsburgh, PA area.
Thanks!
short block machine shop cleaned and checked ,1968 340 block std bore std std steel crank std 340 stock pistons,stock rods new arp bolts , new cam bearing and freeze plugs not installed used a little comp hp double roller chain with gears ,oil pump drive ,front cover ,water pump, steel crank balancer ,windage tray NO PAN new clevite rings,bearings. $1775.00 ohio
i have from 70 340 dart, located 11729 NY, ~400 miles east and can meet you in NJ for extra cost.
BLOCK -- .040 just back from machine shop - clean up hone, new cam bearings, new distrib bushing, has brass freeze plugs
HEADS - x heads, fully rebuilt
CRANK - stock, 10 or 20 under i forget, just cleaned up at machine ship
RODS - stock rods with like new KB pistons
TRANS - matching 727 for the block, rebuilt by previous owner, i never ran it
MISC - windage tray, oil pan, timing cover, oem balancer, hardware, i can throw in an aluminum intake to make it complete for you
Needs bearings/gaskets and final assembly, machine shop is wait listed for assembly, i am going crate motor.
$3500 obo
