[Found!] Slant 6 carb.....1 bbl
barracudadave67
Burlington, Wi.
I am in need of a slant 6 1 bbl carb. The fuel inlet in mine is stripped out. The brass fitting can be pulled out with your fingers. I can't move the car the way it is, and my wife is pissed, its in her spot.
I actually just need the bootom half with the inlet and fuel bowl.
The engine is a 72 model, all stock, in my 66 B-Cuda.
So what do you have,???I am in S.E. Wisconsin.
Thanks
Dave
I have a couple of them laying around.... I have to find them and can post pics later...
What model are you looking for???
Krazy
Not quite sure. I'll have to look closer tomorow, when the mosquitoes arent around. Its not a paloution carb. All it has is the linkage, gas line, and one vac line,and PCV hose. One idel mixture screw.
Well I went and looked. It says
"Ball+Ball" and on the base it says 1745, right by the mounting screw.
Heres a few pic taken while fighting off mosquitoes. You can see the threads are gone in the inlet.
Dave
65
Would you have one like in the pics. I can't drive the car at all. Need one just for parts if nothing else. I ca't figure out how the inlet got stripped. It was leeking i put a wrench to it, and it fell out. I was even looking for the next larger fitting to put in.
Let me know.
Thanks Dave
