[WANTED] slant 6 oil dipstick and tube
60jerry
Denver, CO
Rating - 0%
0   0   0
My engine needs a dipstick and tube from any slant. The desired would be the later slants with long tube to clear A/C parts. I pretty much need any matching slant 6 stick and tube.
Thanks,
Jerry
Thanks,
Jerry
I have this one from a 67 318, not sure if it would work for you
Would a 318 tube and stick work in a /6?
Hey Joe. Thanks for the reply. For my purposes the 318 stick and tube would work for me. I'm trying to route the tube away from hot items, so I would be cutting and welding to make all fit. Interestingly, just last evening I located the stick and tube parts that I can use for this project. I do agree that just as-is the 318 part probably wouldn't be a straight fit considering the distance from the bottom of the tube to the oil level may be different.
Thanks
Jerry
