Anyone here built a /6 run stand? I tried searching but only found small & big block info. I have a Ford flat motor stand I'm going to try to modify. My questions are; What did you do for a flywheel? I'm running an automatic. And what did you do for the bellhousing for starter mounting? Thanks!!!
