I have a 273 that's apart its stock bore stock crank year 64 I'm a big block guy the only reason I kept it was someone told me the crank is the same as a 340 is it worth anything or is it scrap iron only?
Yes, the change year is 68. 67 down is the same, 68 up should be the same. I had my torque converter build with the smaller register to fit my crank.Is the torque converter register smaller on the 64 273?
I have a 273 rocker assembly if you're in the market.Save the adjustable rocker assembly and sell it to me
