Small Block Rebuild Books?
nm9stheham
Waynesboro, VA
Can anyone recommend a very detailed small block book that has a lot of the technical details like internal dimensions, casting numbers, etc.? I see an old on by Don Taylor that looks to be out of print but has a lot of data per an online view; it sells used pretty high ($70-75) but if it better than others, I'll get it.
Tnx to both of you; I finally found the 'look inside' for the 2nd one and it has tabulations of technical data, so that is good for what I want.
