67Dart273
Or at least I am, LOL. I've always been a 'low buck' guy, and the whole Dart has been "low buck."
So here I am buying "fancy new stuff"
I had played with a used Holley Pro-jection EFI, then found a (used) Holley Commander 950, which I got running "fairly well," ......but......
The low end off idle launch is not that great, and you REALLY need two guys to program the thing. You really do. The logging software only goes so far
I was considering Megasquirt, but frankly, it's fairly convoluted, and by the time you add up all the bits and pieces, AND the fact that REALLY there isn't any actual support nor guarantee of any kind....................
So with the advice of Danny over at the Holley forums I finally pulled the trigger on this, on sale, over at Jegs, IE this seems to be the least expensive path to upgrade from the Commander system.
http://www.jegs.com/i/Holley/510/55...K-5wtmqvrgCFeV7QgodBlgA5A&CA_6C15C=1797510431
This has more options and much improved software over the old Commander as well as "self learning" (via the software) capabilities
And who knows, this may be a mistake.................
This is not the turn-key system, this is the ECU and harness kit, and all sensors to upgrade an existing system.
