WSUTARD
The FSM states 30 foot pounds for the spark plug torque. I started but stopped because it doesn't feel right to me. Can anyone confirm the torque specs?
What year and engine? It probably doesn't make make a difference but just in case. I never torqued mine. Just snug with a 3/8" ratchet.The FSM states 30 foot pounds for the spark plug torque. I started but stopped because it doesn't feel right to me. Can anyone confirm the torque specs?
Nice chart!30 ft lb CANNOT POSSIBLY be correct
That's what I "thought," anyway
http://www.autolite.com/media/11853/torquespecs.pdf
finger tight, then 1/2 turn. 1/16 without gasket.
The specs are confirmed by the FSM and Autolite. The Autolite chart shows finger tight then 1/2 turn is in the range of the torque.
All I do is tighten them just enough to crush the washer, plus a little more. It's easy to feel.
Do you use antiseize on aluminum heads?
Always...Especially late model vehicles.Do you use antiseize on aluminum heads?
15 ft/lb on aluminum heads. And yes, use anti-seize.
