spring mount measurement
Realest
gearhead 4 life
Alberta
Would someone do me a favor and measure the width of the front spring mount? I am need to collect material so I can build my rear dollie legs for my dart and I am not around the car currently. I need to know the width of the spring mount so I purchased the proper sized square tubing to fab up dollies similar to the photo below.
[/URL][/IMG]
Thank-you
Ryan
They are 3" internally, where the flange of the bushes seat on.
Thank you sir. A 3" o.d. Square Pipe or even round should do the trick for me then.
Another question to help me build this dolly. I am still not close to car and need to know what size bolt is used for spring eyelet. And bolt nut size. I can't remember if I removed it after I cut the leaf spring to remove the rear axle.
I just want to buy new bolt and nut to attack dolly to spring mount. So I need to know size.
Thanks
5/8 shank. The head is 15/16 I believe that is what I used on my U.S. Cartool leaf spring relocation kit. But I think the factory ones were 7/16 or 1/2 inch
4 1/2- 5"
Stock hangar bolt on my.71 dart was 1/2".
With the SS 002-003 springs new.hangar.bolt.is 5/8-4 1/2"
