2 fast z28
hy guys just bought my spring relocation kit from pst couple of questions first i went on bigblockdart.com read through the instruction they had on there and one thing that didnt seem right was the rear end pinion angle what should it be set at, second they also talked about the rear shackles and using one of the existing hole in the rear frame but they said that u would need longer shackles so were should the hole be then, the last question is that i also just bought my rims and tire the rears are 295/50/15 with a 4.5 inch back spacing on rim will these tires fir in the wheel well or do i have to center the rear end in the wheel well if so whats the best way of doing this
